Need help with trim
Test flew my super sportster 40 after rebuilding from a crash (some 10 years ago!). Flying with an OS 50 SX. First flights needed 5-6 clicks of right aileron and 2-3 clicks of right rudder, 1-2 clicks of up elevator, after which flew straight and level. In turns, the nose drops some. Checked lateral balance and, if anything, the right wing is a little heavy, but not much. Figure the nose is still a little heavy causing it to drop in turns....need help with all of the right trim?? Add left thrust??
