RCU Forums - View Single Post - Speed Control Help
Old 01-15-2005 | 03:43 PM
The Ghost's Avatar
The Ghost
Default RE: Speed Control Help
With no brake, switch the transmitter ON, throttle to full speed. Then connect the battery to speed controller, should hear 2 beeps from speed controller, then move throttle to min, should here 3 beeps from controller. Will be set and won't need to be reset untill you change radio settings. Make shore that the motor is conected and securely mounted before connecting the battery to the speeed controller.
Cheers.
