RCU Forums - View Single Post - DF Forceone by Balsa USA
Old 01-16-2005 | 11:31 AM
sderyck
Default RE: Its called the Sunspot.
Hello Gentlemen, this is not specific to the forceone but to it's pusher design.
I looked around in the shop and found most of what i needed to build a "Zaggi on Steroids" 96 inch wingspan with glow engine
I am almost done and was in the middle of installing the the fuel tank myself stuck.
How is it designed on the Force One? is the tank installed in the same orientation as a puller(normal) prop? opening of tank facing the front of the plane with clunk towards the back?
To keep the fuel lines short i want to mount the gas tank in backwards but this means during a serious climb or nose up on a low fuel level tank it might lean out.
If anyone can take a quick picture of their set up or sideview of plans i would appreciate it. Or direct me to a website or picture that is already out there somewhere on the internet
thanks in advance
