RCU Forums - View Single Post - DWE Micro P-38
Thread
DWE Micro P-38
01-18-2005, 09:33 AM
8
Greg Covey
RE: DWE Micro P-38
Scott,
You're right. It may be worth calling DWE or DU. I suspect that they will be available shortly.
Although my RFFS100 module came with a long wire antenna, I decided to use the loaded Azarr M-72 Indoor antenna from [link=http://www.ecubedrc.com/antennas.htm]E Cubed R/C[/link].
Before mounting my fuselage to the wing, I cut away the elevator and mounted it to the horizontal stab using the supplied rubber hinge material in the DU magnetic actuator kit. I simply cut out 1/8" slot in both ends and glued the rubber pieces in place using a dab of 5-minute epoxy. Note that the use of only 2 rubber hinges will prevent binding and put a minimal load on the actuator.
Reply
Like
Greg Covey
View Public Profile
Send a private message to Greg Covey
Visit Greg Covey's homepage!
Find More Posts by Greg Covey
View iTrader Profile
