RE: DWE Micro P-38
The two motor pods simply pressed into place. I first drilled a small hole for the wires to come out the bottom side toward the center pod. I then drilled two more holes to run the wires into the pod. This worked out nicely because I could use the stock wire that came soldered to the motors and connect to the RFFS100 module without any soldering. I was also able to stuff both sets of wires into the receptor pins.
Note that before positioning the RFFS100 module in the center pod, I pressed the Azarr antenna onto the receptor pin and fed the antenna wire out the stock hole in the rear of the center pod. The RFFS100 module is wedged into place with a tiny piece of balsa.
