RE: Need help on a Douglas A20A Havoc
Flying models (I think, plans are not labeled) released a set of plans for a Control Line scale A-20G Havoc in the early 90's. I have a copy of the plans and they span 54" and uses a pair of 25's for power. Keep this model under 5 lbs and it will be ok. To convert to RC just remove the bellcrank and build it as you would normally and install rudder and ailerons. I built an A-20 from these plans and it came out really nice.
To convert the G model to an A model put a glass nose on and remove the glass turret with a glass canopy area and a gun, otherwise all other shapes are the same I believe.
Good luck,
Fred
