RCU Forums - View Single Post - Removing decals...
Old 01-22-2005 | 08:58 AM
WCB
Default RE: Removing decals...
I have done this: get one edge of the decal lifted slightly and start wicking denatured alcohol under it. Keep wicking the alcohol under it as you gently lift and pull as the alcohol releases the adhesive. Once the decal is removed go over the area with denatured alcohol on a rag to remove the adhesive residue. The downside is the decal can't be used again.
