I have used the Great Planes filler on a bunch of models. They only require the normal two hoses to the tank. You simply insert the fitting into the fueler and it closes the path to the carb and directs the fuel to the tank. When you remove the fitting, the path between tank and carb is automatically restored.
http://www.greatplanes.com/accys/gpmq4101.html
Bob
