ORIGINAL: CEN_Drifter
hi, i have CEN CT4s and i am wondering what is your ct4s's drifting setup? and are they good drifter?
Firstly welcome to the forums! The CEN CT4S should make out to be a great drifter for you. A few things determine how you should set-up your car though, what kind of tires are you going to use?, what surface do you plan on drifting the car on? If your answeres are pvc/abs and concrete/pavement you should be looking for a nice soft set-up to soak up all of the bumps and imperfections, it also gives you the most traction. Alot of people say make your suspension really hard in the rear and medium in the front, but with using pvc/abs you already have next to no traction. If you're going to be running a drift radial tire, or yokomo's wide drift rings you may want a stiff rear-end and a medium front-end. Hope that helps.
