That looks like a decent switch, but one thing to consider, you will be installing it in foam, therefore the switches that have the combined charging jack would be easier to install, just one nice rectangular hole for both. for that one, you will have to make an additional smaller hole for the charge jack, a hole that small would be kinda tough, the foam is real deep in that area, if you use a soldering iron to make a path for the wires (from inside the fuse, up to the depth of your cut hole) , you will end up with a much bigger hole than you wanted, as you go for the depth, it'll really wallow out the diameter too.
