There's a guy on here that mounted his flywheel against the chuck on his drill press and spun the flywheel against some sand paper that was on a flat surface.
Sorta like my routine on the flywheels. Use a 4" cutoff wheel chucked in the press, set the desired cutoff height of table, belt the press to high speed, and slowly rotate the flywheel on the table. Here is some pics[link]http://www.rcuniverse.com/forum/m_1821862/anchors_1821862/mpage_1/key_flywheel%2Cdrill%[/link]
How do you hide a link? Don't think my attempt worked.[>:] copying properties of post did not work.
Do a search for thread: Flywheel mandrell for Homelite 25/30?
