RE: Kit bashing the Top Flite Bonanza to a Barron!!
I have been looking into doing that. I used to own a B-55 Baron and a few Bonanzas. The B55 fuselage is the same from the firewall back. The wings need an extension on the tip. The horizontal and vertical tail surfaces would need enlargement. I would build a fiberglass nose and use the nose gear in basically the same position. The main gear could remain the same.
