ORIGINAL: John Redman
Dave, glad to hear the P-60 worked for you. The max rpm of 162K is 3,000 below the factory default max rpm limit. Did you guys turn the engine down? .....
John / Dave: I checked the actual log file and the highest rpm on the
first run was 164,850 at 635 C with the pump voltage at 2.15 volts.
Dave you can turn on the ECU / GSU and check the highest rpm's on the last run of the day (you know, the one you did entirely on your own! Hoorah!!!!)
Nick
