RE: tf p-47 gear install
If you use blind nuts, then use a bit of non-permanent thread-locker. That will keep the bolts from coming loose due to vibration. You may have to modify the mounting plates to make them thick enough to retain the blind nuts. Shouldn't be difficult.
