RCU Forums - View Single Post - Brushless F-27 Stryker
Old 02-17-2005, 11:26 PM
Pyrock
Default RE: Brushless F-27 Stryker
Toomunsch,
That explains it. I figured you were talking about the stock set up.
As far as your Motocalc number, they seem a bit low because I copied the setup from others on this board who used a similar set up and they say it screams and goes like a raped ape. Regardless, I may get 7x6 prop or 7x7 but I dont want to fry anything. Sorry to mooch off your Motocalc but what is the most aggressive prop I can use while still be within the specs of my electronic system??
Thanks in advance
