RE: Engine mount changed thrust line.
It would be acceptable if the underside of the engine mount beams are parallel to the top side -- however, they often aren't. If not, you will have to shim either the mount on the firewall, or the engine on the mount, to bring the engine back into correct up-down alignment.
