RCU Forums - View Single Post - Brushless F-27 Stryker
Old 02-27-2005, 12:38 AM
  #36
toomunsch
Default RE: Brushless F-27 Stryker
FoamCrusher - You seem to have experience with the brushless swap and I'm in the middle of my first one and have a few questions. My stock motor has a slight angle to it when viewed from above - is this an intentional thrust angle or just factory slop? Do you recommend any aileron diff for this setup? I know there are prohibitions regarding breaking the sound barrier and causing sonic booms in domestic airspace - If I do this how much time will I get? I just fired up the motor and it sounds quite wicked. I put the Sonic Combat Module on a momentary switch and it works great!
