RE: 1/3 Scale Suzuki GSX-R1000 Tyco Bikes!!!!
hey guys the bike was ablast once we put the brushless kit in it but you are right it is just a toy but what my brother did was put a cut out rubber inner tube on the front tire it hadled well we got it uot to about 25 mile an hour so unless you want to make a plate for the bike so you can change the gearing dont waist you cash get a real r/c bike ... but after saying that the ricky carmichael bike is a blast i run a 10 single motor in mine it is so sick fast and easy to handle just either raise up the gards a little for better turning or just remove them you cant go wrong with this one because its mad up almost like the real kyosho bike it is fully capable to be converted into a real deal r/c bike if you want i can send picks of mine of what was done if you need any ideas. Right now im running a D6 10single and a LRP speed control with a 525 stearing servo and i went up a couple of teeth on the pinon gear you will have to grind out the metal mount for the motor...
