One trick that I use and has helped a little is to take a T pin and run it through the balsa so that it goes into the hole on the plate. By doing this, it makes a path for the drill bit to follow. Other than this idea and the drill press, I agree with the others that say "practice." Of course, you can always convert to a single post control horn...but where would the fun be in that?
