Laser arrow delta need help
Hi all,
I just purchased a 2nd hand laser arrow, and am unsure where the C.G line should be, Also I wish to fit a rossi .45 to it which presents 2 problems.
1st, is the previous owner had a os 61 on it which means the ply mount hole for the motor is too large for the rossi.
2nd . is the rossi pipe fouls the leading edge,
will this solution work,??
I want to glue and screw a new piece of ply on top of the current one which will lift the motor approx 4-5milimeters and allow me to cut the new
mount to fit the rossi. Will lifting the motor affect flight in any way,
Also is there a downloadable manual or setup instuctions for this plane, ie, throws cg ect..
Any help most welcomed
Jeremy
New Zealand
