Old 03-01-2005, 09:12 AM
  #2521
jrjohn
My Feedback: (24)
Default RE: Extreme Flight 87" Yak 54 - Build & Fly
David, I might as well tell you what I'm thinking (i've done this in the past) Take the wheel axle and grind the corners off the flange nut to make it round. Then drill a hole in the wheel pants the same size as the now round nut. Then I like to make a bearing out of wood and epoxy it to the other side of the wheel pant (inside) And of coarse the two 4-40 screws through the landing gear into the wheel pant to stop it from rotating. "The slit they have in the wheel pant really weakens my set up
John
