RCU Forums - View Single Post - lanier ultimate biplane
Old 03-01-2005 | 04:07 PM
martyg
My Feedback: (42)
Default RE: lanier ultimate biplane
ORIGINAL: friday
thanks martyg for the info
what brand of servos, reciever and trans would you recommend
OS 160 would be fine if you want a glow motor. Keep the RTF weight below 13lb.
This is not a real hard airplane to fly, but I would recommend prior 120-size experience before attempting.
If you are new to this size aircraft (sorry, but it sounds like you are) get a local mentor to help you.
In mine I have a Brison 2.4 (40cc gasoline) - This is at the upper end of "overpowered"
(2) HS-5625 on ailerons (One per side with interplane linkage)
(2) HS-5625, one per elevator half
(1) HS-5945 on rudder
(1) HS-425 on throttle
Hitec Supreme Super Slim Rx with a 5-cell 1650mAh NiMH battery
Do a search on this plane in the forums. You'll find a lot of good information.
