RCU Forums - View Single Post - 8 ft of bones! Sr Telemaster
Old 03-02-2005 | 06:33 PM
Gray Beard
My Feedback: (-1)
Default RE: 8 ft of bones! Sr Telemaster
To keep the bubbles out all you need to do is lower the temp of your iron just to the point were it will make the layers stick, then when you get everything down the way you want it turn the iron back up to it's normal temp. and just iron down the outside edges, about 1/4 inch around the outsides. If you get A bubble just poke it with A sharp pin A few times and iron it back down at A lower temp.
