RE: Joining monocote
Hey! Guy's I have found something that sticks the monocote to monocote perfectly. No bubbles. As you know the trim solvent works but if you let it touch or don't have it arranged perfect you are doomed. I was experimenting and found some stuff under my kitchen sink that works perfect. Used a foam brush to apply, get it saturated with it ,and brush on very wet, lay piece down and squeegee out. Does not stick immediately like the solvent but once you squeegee it is there. Go over it several times with the credit card or squeegee. Let dry overnight and it is stuck. NO BUBBLES. If you were to try and pull it off you would tear the mono underneath it. That is how good it sticks. Bought it along time ago don't remember when or where, maybe K-mart. Looked online and found it ,so it is still out there somewhere. It is a stain remover Made by JOMAPS INC. The name of it is (M-1 Remover).
