RCU Forums - View Single Post - slo stick plane problems
Old 03-06-2005 | 08:13 PM
BrunswickOH
Default RE: slo stick plane problems
Is it only under power or does it also turn right on a glide? If it's only under power then you can correct it by pointing the motor about 3 degrees down and right (this can be done by many creative methods) If it also does it under glide then the problem is in the setup of the plane, check the main wing to make sure it's not cocked one way or the other.
