RE: Brushless F-27 Stryker
Toomunsch,
I left you some things to check at you RCGroups post. 1 other thing with the right trim problem you had, make sure motor is dead straight in line with the fuselage, if it's off just a little, it will be trying to push the fuselage sideways, making it want to turn. Hence the large amount of trim to compensate.
BJ
