RE: Brushless F-27 Stryker
Thanks for the info - the motor is off a little - the rear (prop end) is more to the rt than is the front. I thought that might be designed in but I guess not. As far as it needing a lot of down trim, should I raise or lower the prop end? Not sure with a pusher.
