RCU Forums - View Single Post - slo stick plane problems
Old 03-08-2005 | 10:05 AM
Epoxy Cup's Avatar
Epoxy Cup
Default RE: slo stick plane problems
Bratnewton
Check the above as mentioned. One other thing, one of my SS's had a twisted aluminum fuselage and if you look from the front of the plane holding it out from you the wing and tail should be parellel.
Like this
---------------------------------------------------- wing
---------------------- Tail
If they are not parrellel twisting the fuselage will generally kink it and break it. You can try shimming the tail mount with a popsicle stick or the like, or get a new fuselage, they are available.
Wow for some reason when I post it aligns right by default. That tail line should be center to the wing sorry.
