ORIGINAL: wgeffon
ORIGINAL: bodyworks
......and FORGET about any type of controlled 3D flight...no Walls, no Elevators, no Harriers, etc
I have to disagree...
IMO, 3D is the last place you'd see any negative effects from a low stab / Crooked fuse etc..
3D flight is slow.
Trim, Incidence, warped surfaces etc wont show up untill the airplane is at a constant, moderate speed.
I have flown some awesome 3D planes that were so messed up as far as throws, incidence, thrust angles it would make you sick.
The only times the negative effects show up on those planes is when the plane is flying with speed.
Perfect example is I flew 35% a few weeks ago. The planes owner is someone who 3D's that plane as good as anyone out there. He makes it look awesome when he's flipping and flopping it.
I tried to fly some sequence stuff with it and thought there was something wrong. I landed and started to look over things.. NOTHING was set up correctly.
All I am trying to say is that stuff like this doesnt show up in 3D.
