RE: Adding Flaps to an already built Chippy?
Hi Rick,
Most hobby shops sell music wire and you simply bend up your own torque rods to your custom size. It is unlikely that you will find the correct size available but you could order from Goldberg. I'm sure some one will give you the part number but if not I can dig it out over the weekend.
The Trailing edge stock is also usually available however if not at your LHS it is quite easy but slower, to get around. Providing you can get the correct thickness (maybe laminate two thinner pieces?), just make up a beam of the correct cross sectional dimensions and razor plane and use a long sanding block to create the section/shape you need. Very theraputic with a cleansing ale.
PM me if you need the part Number.
Cheers,
Colin
