sealing coro edges
Is this the same as Elmers "Pro Bond" Polyurathane glue . It expands a lot while curring . I have heard someone talk about mixing with water . I have used it on wood and it takes only a little bead and then expands into a firm joint . I have not tried it on coro. How do you clean your coro prior to glueing?? KEITH
