ORIGINAL: rorywquin
John
Many thanks for the detailed reply.
On the U/c, do you think that the shorter (less flexible) legs may have contributed to the mounting block splitting?
Good advise on the epoxy coating. Is the heat shied ordinary aluninium ducting tape?
Can you tell me the servo count please.
It is hard to tell from pics but it looks like
1 - steering
1 - flap
2 - aileron
2 - rudder ??
1 - elevator ??
Rory
Not to throw a cog into those US fliers of this airplane, but what are folks planning to use or do about brakes on this airframe? By the AMA turbine rules there must be a brake system onboard that will stop the airframe "on command". I believe this was a recent change in the rule set.
Cheers,
