Wayne - is that a 9Z I see on the bench???
LOL
ORIGINAL: wgeffon
John,
The blank sheets are transfer sheets. They are all sized to fit over each individual grahic.
Peel the backing off the transfer sheet. (blank). Lay that down over the actual graphic. Smooth out all the bubbles and now pull the graphic off its backing with the transfer sheet. Now all you have to do is lay the transfer sheet with the actual graphic in place, rub the graphic down with your finger and then pull the transfer sheet off the actual graphic.
The key to keeping the graphic in place while the transfer sheet is beign pulled up is to pull the transfer sheet 180 degrees back on itself. You dont want to just pull up on it. Peel up one corner and pull it back all the way so its touching the surface and go from there.
Does that make any sense??
Mike,
How are you doing your choke?
Drew and I are just using a piece of Nyrod that stick out the from of the cowl. Push and the choke is on pull and its off.
Simple!
