RE: Stuck on Epoxy
K-DOG , The moderator is right and wrong at the same time. EPOXY is 1/4 CA glue, so there are some epoxies you can and can not use. and if you do a search on epoxy they will give you and explanation of what each type of epoxy is used for foam.
Good luck.
