ORIGINAL: Cyberfyn
Hi. Have you sorted out your MX yet? I have the same TX and It's always worked brilliantly for me. If you want me to scan a copy of the manual and sent it you I can. It has a detailed section on the setup button.
Regards. Ian.
Ian, thanks, I've got it now. Still having problems with TX/RX. I'm wondering if putting in eight 2000 mAh AA batts, then charging them through the charging plug, could have damaged the unit. It doesn't talk about using these batts and charging this way in the manual, but it makes sense. I'm used to batt packs in my "airplane" controllers (9CAP), so putting batts in loose like this is new to me. Do you think this was wrong?
