carlos and all ,
well i have my SS EP all done and went to balnce it WOW it is nose heavy, even after i had built it with the servos to the back of the servo area. so i decided i would try and move the battery pack back as far as i could and then had the wing servo hitting the battery pack aaarrrrggghhh !!!! well i then used a balsa wedge block at the very back of the battery tray and was able to get the battery to go high enough to clear the servo.(still needed to add a little weight to balance it) now works like a charm and i even have enough room there to try an 8 cell pack of my SCR 2400s
ran up the motor and was very pleased with the power the plane seems to have while using the SCR 2400 7 cell pack ( stock prop adapter working fine). thanks for all the posts on this great bird have fun flying it
bassman
