RE: HELP PLEASE SH28 TO HOT!!!!!!
THe nova head is one of the strongest most efficient heat sink heads available. Keeps your expensive engine running cooler, so it will last longer, run leaner and smoother.
This innovative design has been tested time and again for the perfect combination of size, strength and heat displacement. While maintaining an affordable price!
A high efficiency 7075 aluminum heat sink to keep your motor running cool and efficient even under the most demanding conditions. The low profile lessens the chance of taking damaging blows and the possibility of shearing off your motor mounts.
It still reduces temperature and plus, it has more colling head fins.you can reduce temp of up to 40 degrres which imo i think would help. its his decision to get one and if he wants to see less enigne temps.
