RE: 120VAC to 12VDC converter???
Red , Thanks for the info on the Pyramid power supply, the prices are excellent.
I have a Radio shack 10 amp that I purchased on clearance for $39 and their 25 amp switching power supply that was on sale for $59.
Are there any problems using a switching power supply? My 10 amp power supply is much bulkier than the 25 amp.
Everyone seems to recommend 13 amp minimum for their charger but I would assume as in the case of the Triton you would only need the 13 amps if you were charging 24 cells.
Wood Duck
