RE: Extreme Flight 87" Yak 54 - Build & Fly
I didn't want to tie my elevator extensions down too permanently as I may have to remove my stabs for transport. I was planning on heat shrinking the servos to the extensions and removing the whole deal if I have to to transport. Since I went with the original listing on Drew's site about 24" elevator extensions, I don't have enough length to allow unplugging only the servo from the extension.
I had thought about thick CAing the rx antenna to the formers back in the fuse but running the antenna parallel with other wires was also a no-no in the past. I didn't like the idea of running it straight back basically parallel to the pull-pull wires and the elevator servo extensions. If it's not a problem, I'll either Ca it or run it in a nyrod tube CAed to the inside of the fuse.
Anybody tried to fit the finished fuse with stabs in the back of a shortbed Chevy truck? If it'll fit I can make my elevator extensions a bit more permanent.
Matt
