RCU Forums - View Single Post - Extreme Flight 87" Yak 54 - Build & Fly
Old 03-28-2005, 11:46 AM
  #3741
matus777
Default RE: Extreme Flight 87" Yak 54 - Build & Fly
"quote:
Do you use tygon inside the tank? I cut a piece and put the clunk on it but it's too stiff to fall on it's own. Instructions with the gas stopper say to use the black stuff (brain fart, I can't think of the name). "
You might be refering to NEOPREME hose? I have used it with no problems. The only thing you need to be aware of is the size, ID. Some of the stuff is too thin walled and can tear easily when whipped about by the clunk. Make sure you use the thicker material and that your tubing does not have sharp edges....i drain my tank and have not had any issues just make it right sized for your tubing.
