RCU Forums - View Single Post - New SPAD Foamy Design!
Old 03-29-2005, 12:16 AM
-pkh-
-pkh-'s Avatar
Default RE: New SPAD Foamy Design!
Here are some build photos of the fuse... I've left the left side of the fuse open to facilitate wire routing & electronic parts placement for balancing. After I've settled on the mounting position for the RX and batt pack, I'll add 2-3 more stryrofoam formers and glue the left side up. I will cut an access door in the left side to get at the batt pack and RX. The hole in the bottom of the styro fire wall is for the stick mount... I'll put a PVC doubler on the bottom front of the fuse and screw the balsa stick down to secure it. I prefer this over gluing it, so when I crash it, I can easily replace the stick.
ID:	250901   Click image for larger version
ID:	250902   Click image for larger version
ID:	250903   Click image for larger version
