.46 or .52 for magic extra?
i just picked up the modeltech magic extra yesterday. is a magnum .46 enough for solid vertical performance? i'd dont care about "over-powering"
the plane but good vertical performance is a must (be able to pull out of a hover easily). i've heard that the .52 is more than enough and even "too much" for this plane.
so should i stick with the magnum .46 ($79) or go with the magnum .52 ($89)? $10 difference is of no consequence but i was more worried about the extra weight, and modifications to the mount and also why get it if the .46 can give it what i need. also, what prop should i use for the recommended engine?
also, i was thinking about using mini servos for everything except the rudder (standard). is this a good idea? this should save a few more ounces.
this is my "first" glow plane. (i had a .10 glow trainer years ago when i was just getting into the hobby as a kid). since then i've only flown electric.
thanx.
