RE: Modified All Star Bipe CG?
Might even check the balance before you tap and drill the engine mounts. Slide the engine back and forth to try to get the correct balance, and then if you're not too experienced a pilot, add some removeable weight to the nose to get it SLIGHTLY nose heavy for the first couple of flights. It doesn't take much tail weight to rekit a plane, compared to nose weight.
