RE: Big problem
Is the D1 shaft or belt drive?? If it is belt drive and has ball diffs the only way I see it could turn the front bacwards is if the belt has a twist in it before it gets to the front diff. You know the top of the belt is going to the bottom of the diff no the top like it should.
