RCU Forums - View Single Post - 1/4 SCALE CAP 232 FORUM
Old 04-07-2005, 04:38 AM
  #71
RustyTumbles
RustyTumbles's Avatar
Default RE: 1/4 SCALE CAP 232 FORUM
I replaced the servo's in the extra with Hitec karbonite digitals soon after I purchased it (secondhand). They now have around 12 flights on them and I have had no probs. There is no slop what so ever, the improvment they made in the aileron response was very good. Just make sure you get the new versions with the 10mm servo arm screw. The old ones had an 8mm screw and the were known for shearing at the output shaft... Also don't over tighten the mounting screws as I have been told this can lead to uneven loading of the servo case and gear breakage!!
