Congradulations on your Solo Flight!
How bad is the Xtra Easy? Is the wing destroyed? If not you could make your own fuselage. You might be amazed at what ca glue and epoxy can accomplish in repairing the old plane.
Balsa Usa has a stick 40 trainer that is extremely tough also. You might get some ideas from looking at it. One time I did an inverted flat spin that I didn't get out of in time(pancake splat) with a Balsa USA Super Stick and in 40 minutes I was flying again.
http://www.balsausa.com/kits/kit.htp?id=39&shopperid=
