RE: Phil Krafts Original Ugly Stick
FYI. The Stick was designed as a test airplane (w/o cowl) and was built by Danny Lutz for that purpose. It seems Kraft, Inc. needed a quick to build, easily replaceable and inexpensive airplane to test experimental radios. Danny built all of Phil's airplanes as he worked for Kraft, Inc. If you will notice the engine is side mounted to allow the carburetor and the fuel tank to line up correctly. That's the same reason that the engine is tilted in Kraft's Quik Fli. Dwayne
