Not helping me here David
, you know I fly Futaba
I know the 10x has a gyro field that the futaba systems do not have.
From what you stated I gather that you have a estimated spot on the dial that you turn it to get the required 60% gain gear down? From there you can add or subtract gain by rotating the dial in the required direction?
Am I correct in assuming that the amount of gyro gain is directy controlled by the amout of ATV (EPA) you give the aux gyro channel? If this is the case then if I leave the ATV at 100% with the dial mixed in, I would turn the dial to what I perceive to be 60% of the total dial rotation?
Any Futaba fliers out there know the correct way to set this up?
Todd
