RCU Forums - View Single Post - tips for first time build
Old 04-20-2005 | 09:56 AM
FLYBOY's Avatar
FLYBOY
Default RE: tips for first time build
I don't use pins, I just glue them while holding them. CA works so fast pins are not needed unless you want to use them. I wouldn't suggest sticking them in your wifes kitchen table. Also, if you are building there, things are going to get messy and dusty.
Put carboard on it so you don't get glue on the table. Might put something over the carpet cause you will make a mess there too.
Get an xacto saw to cut wood too. Much better cuts than a knife going cross grain.
Build slow. Read and understand all the directions well before cutting or gluing anything. Make sure you are doing it right. Don't assume anything.
Don't sand too much. Just lightly. Most people destroy a plane by sanding through the wood. You just want to touch it enough to get the job done. More and you go through.
Don't leave bumps of glue on top. Anything sticking up will show through the covering.
Don't run glue all over. It makes a mess and makes the plane harder to sand and cover.
Use epoxy only where needed. Excess is added weight you don't need.
Get help if you have questions.
Get a good instructor.
Have fun and enjoy it. Thats why we fly models. They are a blast if you take your time and don't screw it up.
Last but not least! Make sure you have all the CA off your hands before you hit the restroom!
