RCU Forums - View Single Post - tips for first time build
Old 04-20-2005 | 11:00 AM
RCKen's Avatar
RCKen
RCU Forum Manager/Admin
My Feedback: (9)
Default RE: tips for first time build
Newb,
You're going to need the same things mentioned here in the this thread. The materials, tools, and adhesives don't change too much between kits. They are pretty much the same. Here's a quick list just in case :
CA (thin, medium, thick)
Epoxy (6-minute and 30-minute). you could probably live without the 6 minute if you needed to.
Knive. use an x-acto knive (#11) or single-edge razor blades. or both.
Straight egde. This needs to have a metal edge so you can cut against it.
Pins. To pin down parts. T-pins work best, but straight pins will work too.
Razor saw. Nice for cutting with but not needed
Sand paper. 80 - 400 grit
Sanding blocks. Can be pieces of wood to save money.
Alcohol. for cleaning up epoxy.
This is not a complete list by any means, but a good start.
